Understanding screen measurements
Discussion in 'Archived Threads 2001-2004' started by Rick_Brown, Mar 14, 2003.
  1. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
    I assume that widescreen measurements are done on the diagonal, like 4:3 screens? Is there a formula for determining the straight-across horizontal size of a widescreen TV? Thanks.
  2. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    Rick, I think you might find this site helpful.
    Vin
  3. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    The aforementioned site works well. If you want the nuts and bolts and would also like to work out quick estimates:
    A widescreen TV has a 16x9 aspect ratio, so using some right triangle math:
    D-squared = W-squared + H-squared (where D is diagonal, W is width, H is height)
    and substituting H = 9/16 * W, you get
    D = sqrt(337)/16 * W or W = 16/18.36 * D
    If you want to figure width out in your head, you'll be fairly close using W = 8/9 * D.
    Want a rough estimate of height, use H = D/2.
    Doug
  4. Rick_Brown
    Oct 25, 2001
    449
    Thanks, Doug and Vin - just what I was looking for.
