Under Powered Sub?
Discussion in 'Archived Threads 2001-2004' started by RonaldO, Mar 4, 2003.
  1. RonaldO
    RonaldO Auditioning
    Mar 4, 2003
    3
    First my setup: Onkyo 5:1 65watts, Boston tower fronts, JBL center. My wife bought me a small RCA 50 watt 8" sub, I connected it to my sub out and to the subs line level rca in using a "Y" connector. The bass of my system dropped by 50% and I could barely even hear the sub. Was it the sub just vastly under powered or should I not use the line level output?
  2. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    Did you adjust the volume of the sub at all? and how did you set it up in the receiver? You should be using the line level so that is ok.
  3. RonaldO
    RonaldO Auditioning
    Mar 4, 2003
    3
    yes, the sub volume was at full blast and the Onyko has three different sub settings, nothing ever boosted the bass. I have more bass without the sub then with. Think I should try a JBL 10" 150Watt?
  4. JeremyFr
    JeremyFr Supporting Actor
    Jan 28, 2003
    794
    did you by chance check to see if you had the phase set correctly on the sub, if you're not getting any bass you may have it out of phase with your main speakers which would cancel nearly all audible bass. Also I would ditch the RCA and go with something like a JBL myself to answer that question.
  5. RonaldO
    RonaldO Auditioning
    Mar 4, 2003
    3
    yup checked the phase, and i did ditch the rca lol
  6. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    Also, make sure you change your receiver settings to small speakers.
