Types of cable (1 Viewer)
AlexKunec
What are the differences (if any) between these types of wires:
Digital Wire (looks like rca cable)
Component Video (Looks like 3rca)
Subwoofer Cable
Regular RCA cable
I used to think that all these were basically rca cables, but someone recently said that Digital Audio cable requires 75ohm cable instead of 50 ohm.
Bill_Weinreich
They all are usually coaxial cables. Although some of the real cheap ones are not. Most ( I stress MOST ) coaxial interconnects that you will purchace will be of the 75 ohm variety. The ones labeled digital are designed to carry the higher frequencies and bandwidth of a digital signal. You can use a digital cable for analog but its not recommended the other way around (although it will usually work)
Bill
Bignatt
