Type of Speaker Wire
Discussion in 'Speakers' started by ted*, Jun 8, 2005.
  1. ted*
    ted* Agent
    Jun 6, 2005
    25
    What type of speaker wire should I get?
    Setup:
    HK AVR 630 Receiver
    Ascend 340 Center ( 3 feet from receiver )
    Ascend 2x 340 Mains ( roughly 10 feet from receiver )
    Ascend 2x 170 Surround ( Long distance since I will make the wires go into the wall. )
    I am confused on what type of speaker wire I will need to wire this up and from where to purchase.
    TIA
    Ted
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Ted, ask this in the Speakers area. This is A/V Sources, and source components do not even figure in your post.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Home Depot....
    100' spool of stranded 12-2 (12 gauge 2 conductor Stranded).. $28.00
    But look over their wire when you go there, often they have sale deals, just a ton of mighty fine brands and types of wire that are fantastic for high power audio use.
  4. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    How long would you predict the rears to go? More than 40 ft?
    I'm using the following cables from HTD.com. 14 gauge in-walls (CL-rated for fire retardation) $25 for a spool of 100 feet:
    http://www.htd.com/speakercables.html
    [​IMG]
  5. ted*
    ted* Agent
    Jun 6, 2005
    25
    Sorry guys I posted this in the wrong forum.
    Thanx for your replies. I see speaker wire can run up to $100 and didn't want to buy blindly.
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    This is what you need to know in relation to the legth of your runs:
    http://www.roger-russell.com/wire/wire.htm#wiretable
    Other than that, the wire doesn't need to be anything too specific or expensive, unless you are running the wires in-wall or outdoor.
  7. ted*
    ted* Agent
    Jun 6, 2005
    25
    Its not more than 30-35' so I am going to get 14 Guage.
    Thanx guys
  8. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    Cool. Let us know how your speakers/wires turn out once you get them in and had a chance to listen to them [​IMG]
  9. John_RO
    John_RO Stunt Coordinator
    May 24, 2005
    85
    14 gauge Home Depot wire has served me well for many years.
  10. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    Oh yea, if you're going to get the wires for running inside the walls, be sure they are CL3 rated.
