Two Toshiba Tweaks at the White House
Discussion in 'Archived Threads 2001-2004' started by Chris White, Nov 19, 2001.
  1. Chris White
    Chris White Second Unit
    Feb 12, 1999
    391
    My wife and I completed two Toshiba projects this weekend. The first project was to remove the protective screen from my Toshiba. I reshuffled the screen stack long ago, but this weekend I decided the removal method is better. This page has a few pictures and more details for anyone interested: Weekend Project #1
    The second project was to paint our Toshiba TW65X81. We've never much cared for the gray color and finally decided to do something about it. This page has some pictures and more details: Weekend Project #2
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Kewl!!
    The set looks great in black
    Gregg
  3. John Tyrone
    John Tyrone Agent
    Dec 2, 2000
    35
    Hi Chris. Your set looks so much better visually now that it's black. I had the 50h81 and the gray border around the screen was a distraction. I also had some other problems with it so I bought the mits 55809, which has a nice black frame.
    I might have to remove the screen now!
  4. Francois_Laliberte
    Mar 10, 2001
    21
    Chris,
    it looks great, congratulations
  5. CaspianM
    CaspianM Stunt Coordinator
    Oct 4, 2000
    87
    That was a brave move!
    Looks great though.
  6. StephenMSmith
    StephenMSmith Stunt Coordinator
    Apr 29, 1999
    85
    Holy Moly! I can't believe no one thought of this before! The black looks really good. Plus, all 4 of my screen frame sides have been horribly torn up from taping too many things to them over the last 2 years (overlays, strings, etc). I was planning on spending $50 for replacements from PacParts. Painting just never occurred to me at all, not to mention painting them black.
    Nice job using the noggin', Chris!
    Steve
  7. StephenMSmith
    Apr 29, 1999
    85
    I also wanted to echo your findings on restacking vs. removing the contrast shield. I could never get a perfectly flat and tight screen stack w/the contrast screen moved to the back. I think it's just too heavy and prone to bend and loosen over time as well.
    Did you notice that the corner pieces have clamps that don't come anywhere near the actual screen stack (with or without all 3 screens)? I took my screen stack apart again last week to weatherstrip the corner clamps so the corners are held as firm as the sides. It took a pair of stacked weatherstipe segments to put any pressure on the screen corners. I don't know if Toshiba intended this or not. I didn't have any compelling reason to do it either, I'm just running out of things to do on my set...
    Steve
  8. SHAWN SZILEZY
    SHAWN SZILEZY Stunt Coordinator
    Jan 4, 1999
    136
    Chris,
    The set looks awesome in black. Now you have me contemplating painting my TW40.
    Thx......Shawn [​IMG]
  9. Chris White
    Feb 12, 1999
    391
    Thanks for the kind words guys!
    Steve, this makes me wonder whether there is something wrong with your corner clamps. My corners were a bit loose before, but with the 3/8 weather-stripping they are quite snug.
    [​IMG] My wife got a big kick out of that statement.
  10. Chuck Sullivan
    Jul 13, 2000
    18
    Chris,
    Looks great. Did you use spray cans or brush? Couldn't tell from the photos so how does it compare to the Elite series finish?
    Chuck
  11. StephenMSmith
    Apr 29, 1999
    85
    Hmmm, your corner clamps make contact w/the screen stack w/one 3/8" stripping? Maybe there is something wrong w/my corner clamps. I think Tom H. reported the same gap on his 65H80 though.
    Just to be sure we talking about the same thing: I'm referring to the L shaped pieces w/the 3 angled screws on either end. They have a short stub extension on each side facing inward towards the screen. When they're fit into the bezel pieces, it's those stubs that don't make contact w/the screen stack itself, at least not w/o double-stripping on my set.
    Are we talking about the same thing?
    Steve
  12. Chris White
    Feb 12, 1999
    391
    We used spray paint for the plastic pieces and a brush for the chassis. When we first painted the front center piece, we did coat it with polyurethane to give it the high gloss piano lacquer (i.e., Elite) finish. It looked great, but tended to reflect every light in the room too much so we sanded off the polyurethance and repainted with a flat black finish instead. You can't tell from the lousy pictures, but the base of the chassis was finished with two coats of polyurethane and does have a piano laquer finish.
    Steve:
    Take a close look at this picture: Inside Corner I'm not sure if my corner clamps are the same as you've described or not. As you can see in the picture, the corner piece has two tabs that go inward. It is those tabs that make firm contact with the weather-stripping.
  13. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Chris, bravo on the paint job. It looks much classier and richer now - definitely beats the original toy plastic gray by a long shot.
  14. StephenMSmith
    Apr 29, 1999
    85
    Yeah, those are the clamps. Very weird. It looks like your screws for this piece are going straight in, rather than angled. Is that true? That might explain why your clamps make contact and mine didn't.
    Steve
