A
Anthony_Gomez
I am going to try and use real world examples so that you can model this with your own software.
Suppose a tempest in 260L tunned to 16hz an also a BPD1503 in 160L tunned to 16 hz as well
...after playing around with a few parametric filters you can make the BPD responce look just like the tempest responce from 20hz on up to withing +/- 0.5db (+/-.5db is NOT going to be heard when you consider room interactions).
Since these two systems now have the same responce curve, will they now sound the same within their limits of linear excursion?
(assume that inductance is also accounted for in the EQ)
