Doug Z
- Apr 2, 2003
I understand that polk and swan use a silk dome tweeter and I am curious as to what the major differences are. If the ring radiator in the LSi series are so good why does swan use the silk dome? Personally I think the silk tweeter is much smoother on my RT800's but what does swan do differently, aside from an external mount? I assume they are not exactly the same and I probably will pick up a pair of 2.1's but I am just curious.
