Patrick Sun
- Jun 30, 1999
Okay, I have a bit of a dilemna. I think I will commence on building my DIY speaker stands. I'm using leftover 4" and 6" PVC pipe for the vertical supports, and 2 pieces of 3/4" MDF laminated together for the base and top. I do not look forward to cutting through 6 pieces of PVC pipe!
Currently, the tweeter height for my speakers are a few inches above my ear level when I sit on my couch (this is using my old speakers laying on their sides as the 'current' speaker stands). I know many folks like to have the tweeters at ear level. Well, I'm trying to compromise between life with a home theater setup and a 2-channel setup. This just means trying to get the tweeter heights for all 3 front speakers near the same.
But here's the bad part, I tend to slouch in the couch sometimes, and of course, this lowers my ears in relation to the tweeter height even more.
So what I was hoping for suggestions: What height should I make my new speaker stands? The current setup results in lifting the SunOne speakers about 18" off the ground, and the tweeter is roughly 21" from the bottom of the speaker, so that's 39" off the ground.
The other consideration of the center channel tweeter height, which is probably 46"-48" off the ground. So should I shoot to lift the speakers off the ground 38" or lower (near seated ear level) around 33"-35"?
PatCave; HT Pix; Gear; DIY Mains; DIY CC; Sunosub I + II + III; DVDs; Link Removed
