olskoolfilm
Grip
I wanted to calibrate my home theater using an SPL meter. I have a Yamaha RX-V371 that does not have calibration capabilities. I had an old Radio shack meter years ago. Can anyone recommend a good one that does not cost too much?
Dave the one I bought worked perfectly. I set all 11 speakers with no problems.How well do they work?
The analog meter works very well. I used one with several receivers to set channel levels. For the last couple receivers, though, I have just used the microphone supplied with the unit along with its built-in calibration application.How well do they work?
Since I don't use any type of receiver in my HT I'm curious.....do the receivers I read about used in HT's have built in Pink noise allowing you to set levels with a meter? I'm also curious on the levels most of you have your speakers set on (db levels).
Running Pink noise my stage (LCR) is set on 85db, side surrounds are on 83db, rear EX speakers are on 84db and my dual subs are on 91db.
What say you?
@DFurr what are you using for surround if not a receiver or pre/pro? Do you have a player like an Oppo that can be used in place of one?
Im sorry Im getting ahead of myself, if youre using an analog source in direct mode an SPL meter will be fine, the minidsp might introduce some coloration/delay in the sound signal but will be ok for home theater. It depends on the material and source what direction you wanted to go.There was a digital SPL meter I was looking at on parts express but I can remember what model it was. To take it a step further perhaps using REW and a miniDSP to measure and adjust on the fly or Audessy settings on the receiver.
Thanks for the refresher. I know it should be on slow, but I can never remember what the weighting should be on.Revisiting this thread from almost a year ago, for those persons using the analog Radio Shack SPL meter, MAKE SURE you've got the "speed" switch set to slow and the "weighting" switch set to "C".
