Tweaking rmb-1066 Question
Discussion in 'Archived Threads 2001-2004' started by Jason Caudill, Jul 4, 2002.
  1. Jason Caudill
    Jason Caudill Stunt Coordinator
    Aug 7, 2001
    153
    I added a Rotel rmb-1066 amplifier to my setup this week. I really like it so far and think it meets my needs perfectly. My question is how should I set the input gains on the front? Out of the box, they are all set differently. I have video essentials and a sound meter that I use for setting levels on my receiver. Any advice would be great. Thanks and Happy 4th, Jason
  2. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    From what I have been told(asked the same question), take a flat head screwdriver and turn them all clockwise till they stop moving. This sets the gain to max.
    For a while there I thought I was the only one that owned this amp.:b
    Kevin
  3. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    Like Kevin said, always set the gains to full and then use your processor/receiver to set the levels.
  4. Jason Caudill
    Aug 7, 2001
    153
    Thanks for the feedback guys. I think that this is a very underrated amp. I purchased it to start my moves to separates from my Yamaha receiver. I think that it has a clear, but not fatiguing sound with my Paradigm Monitor 5's. I chose it because a) I wanted to move to separates with the rsp-1066 to follow, b) I am going to be moving a couple of times in the next 2-3 years and I am not sure what configuration I will be able to run my HT in, and C) I wanted to add to my system for 2 channel music.
    I am currently running it at 3 x 150, to power my mains and center and leaving my rears to my receiver. I would strongly recommend this amp to anyone looking for a 3 channel amp. Jason
  5. Kevin. W
    Oct 27, 1999
    1,534
    From the e-mail that I got from a Rotel Tech rep, he says the 1066 specs for THD/SNR in bridged mode are the same as non bridged. So you shouldn't loose out on sound quality.
    Kevin
