Tweaking my Sony SAWM20
Discussion in 'Archived Threads 2001-2004' started by Jim Williams, Dec 13, 2002.
  1. Jim Williams
    Jim Williams Second Unit
    Oct 29, 2002
    367
    So far, in the past 30 days I have spent $650 on my modest home theater without causing any problems with my spouse. I am currently using a pair of Klipsch KG2s for my mains, a KV-2 for the center and a pair of Energy Connoisseur C-1's for my rears. My weak link is my sub, a Sony SAWM20. I know that if I spend any more money on speakers, my wife will definitely have a fit. Does anyone have any tweaks that I can use on my sub so I can get the best sound out of it?
  2. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    ah...hate to say this....but....are you surrreeee your wife won't let you spend an extra $100 on a DLS 10" sub from partsexpress.com? maybe you can sell the sony?
  3. GregLee
    GregLee Stunt Coordinator
    Aug 13, 2002
    103
    I have an SA-WM20, too. I'm happy that it's a clear improvement in my system over not having a sub at all. I'd be interested in a comparison with the DLS 10" by someone who has actually heard both of them.
    Pre-tweak 1: Get it connected the best way. I've experimented with (1) the standard 5 speakers set "small" and subwoofer="on" (which I didn't like), (2) 5 speakers set "large" and subwoofer="both", with sub xover=55Hz, (3) 5 speakers set "large" and subwoofer="off", with fronts connected through the sub, sub xover=80Hz. I'm currently using (3), but I might go back to (2). (My other speakers are full-range.)
    Pre-tweak 2: Get the sub's volume adjusted right. Not easy. I play Jazz with string bass solos and try to get the bass notes at a more or less constant volume, as the bass walks up and down. With setup (2) above, I had the volume at 1:30, with (3) I have it at 10:30.
    Tweak 1: Put a cement block on top to keep the little thing from vibrating so much. Some people rest it on top of a paving stone. I don't know whether either of these helps.
    Tweak 2: Stuff it with polyfiber, as folks do with its big brother SA-WM40. I haven't tried this yet and haven't seen any reports. It's just a thought.
