My TW56x81 has begun displaying a white "halo" effect on very black backgrounds. Can you tell me what causes this and how to fix it? I have SVM disabled (using a fix from HTF)
Is there an "edge enhancement" selection somewhere in the TV menus? Turn that off and also turn the sharpness off. (Note: On some TV sets sharpness off is in the middle rather than the left of the scale).
Only other thing I can think of is the electronics aging and having difficultiy remember "where black is" (black level retention).
Do the halos surround bright sections in an otherwise dark scene? My guess is that you're seeing light being reflected from within the cabinet. This is a "problem" with most RPTVs.
First, make sure that your set is well calibrated using Avia, Video Essentials, or the like. It's possible you're pushing your white level (contrast) too high.
FYI...Some people have opened their cabinets and applied a light absorbing fabric around the inside to reduce this effect.
