I am looking to buy a 4:3 NTSC tv that has no red push. My curent RCA has this. I was loking at the Toshibas. Any thoughts?
------------------ Link Removed
My 27A40 has a very balanced color decoder (i.e. green, red and blue all tend to be around 0 +/- 5 percent when calibrated with Avia using the blue filter. I can't speak for the current model - 27A41 or for the newer RPTVs from Toshiba. I can say that my Toshiba 20AF41 does suffer from red push (+ 15 percent) so I'm not hopeful that the new AF models from Toshiba will do any better.
cheers,
--tom
Toshiba as you suggest, at least the latest and previous generations (the X81 series prior had huge red push, 20-25%). The H & HX series sets run at roughly 5% red pull (undersaturated) - I have made the same reading on my set (50HX70) using Avia, as has Jeff Kowerchuk (56H80), as has Gary Merson from The Perfect Vision (56H80).
--Jay "No one can hear when you're screaming in digital." My Home Theatre Pictures... "You're no mesiah. You're, you're a movie of the week. You're a ... t-shirt, at best."
