Griggs
- Jun 17, 2007
- Chad
Ok, I'm looking to spend under $2,000, perferably under $2,000 with basic accessories or even a service plan.
What I've looked at so far is a 42" and 50" Panasonic Plasma. Seems that 720p is all that is in my price range, Sam's Club carries a 1080i for around 1700. I'm also starting to think about a LCD, maybe a 47" Westinghouse, which is 1080p, or other brand.
Then There is the thought of doing a projection to gain some size. I sort of dislike the LCD projectors because of the screen door effect and the DLPs I've seen in the stores have such bad viewing angles. I've heard good things about the JVC HD-ILA which is a 56" with 1080p for around the same price as the Westinghouse LCD 1080p and just a couple hundred bucks more than the Panny 42" 720p Plasma.
I want to use this new TV for just general viewing in the living room, that will include SD TV, some HD TV, Movies, video games and I would even like to be able to hook up my PC on occasion.
I think I want a Panny Plasma maybe to just have a plasma, I like the bright colors and the screen, although I will not be putting it on the wall at this time. I've been impressed with the LCDs I've seen in stores, easier to see in bright rooms, which would be good for general viewing.
When I compare the 47" Westinghouse LCD 1080p with the 42" Plasma Panasonic 720p I would think that an extra hundred or two would be worth getting a 1080p. Obviously Panasonic is the better brand, so thats one side. The other side is the 1080p would be nice, and the the bigger the better.
Then getting into the JVC which is also a 1080p for a similar price as the 42" panny accept the JVC will be 1080p plus 14" larger; so its getting hard for me to justify the Panasonic just because its plasma and just because its Panasonic.
Lastly to throw a wrench in, I might be able to get as much as 20% off at Wal-Mart which carries a 50" Philips Plasma. This means I would be able to get this cheapest of all. The only downfall from that is that its a Philips, its 720p and I don't believe Wal-Mart has a service plan available. But 50 inches of plasma would be nice.
It seems hard to weight the pros, cons, sizes, technologies and prices, please weigh in with your thoughts and any ideas you may have. Thanks
