TV with These Features?
Discussion in 'Displays' started by Ken Holmes, Apr 23, 2004.
  1. Ken Holmes
    Ken Holmes Stunt Coordinator
    Jul 11, 2003
    102
    I'm looking for a 24-27" direct view crt tv for the bedroom that would have all of these features:
    headphone jack
    raster squeeze
    ability to turn off SVM
    anyone know of a tv that has all of these features?
    Ken H
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    The Sony KV-27FS100. Some Sony models have an IR-based headphone system, which isn't bad.
  3. Ken Holmes
    Jul 11, 2003
    102
    Does this tv have a headphone jack?
  4. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    The Samsung TXN2734 27" Flat Tube does the Raster Squeeze & has a headphone Jack but I don't know about SVM on it though because on Samsung's website it doesn't say anything about SVM so maybe the set doesn't even have it? On Toshiba's you can't turn the SVM "Off" & I don't think the Sony's, JVC's or Panasonic's have a headphone jack on the 27" size sets & none of them wiil do the Raster Squeeze on the 24" models except Toshiba.
  5. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Correct me if I'm wrong but don't Toshibas have a "movie mode" that turns off SVM automatically?
  6. Bill Will
    Dec 26, 2001
    1,282
    Scott, You might be right, I know that on some of the Sony models that was the case but Toshiba doesn't mention anything about the ability to turn it on & off on their website so I just figured that you could'nt. Maybe someone who has a Toshiba set can answer that.
  7. Mark Murphy
    Mark Murphy Supporting Actor
    Nov 20, 2002
    628
    Yes, there is "movie" mode on the Toshibas that turns off SVM.
  8. Ken Holmes
    Jul 11, 2003
    102
    Even the 24" model 24AF43?
  9. Mark Murphy
    Nov 20, 2002
    628
    I'm not sure if it only applies to the regular tube TVs or just the RPTVs. I have a 42H82 42" RPTV.
  10. Bill Will
    Dec 26, 2001
    1,282
    Ken, If I was you I would look for a set that you liked best that had the 16:9 DVD Mode & SVM ON/OFF then if you needed the Earphone Jack any TV Shop can install one it's about as simple as a job you can get & I don't think they would charge you very much to install one either. As for the Toshiba's SVM I would call Toshiba & check it out with them.
