TV to Receiver
Discussion in 'Beginners, General Questions' started by Dennis Sr, Feb 23, 2005.
  1. Dennis Sr
    Dennis Sr Auditioning
    Jan 23, 2005
    11
    Need some help wiring my HITACHI 53sbx01 to an Onkyo 702.For the audio connection using analog {no digital on tv}it says to connect receivers VIDEO IN 3L/R JACKS to an analog audio output on the tv,the only audio output on the tv is an AUDIO TO HI-FI.Is this the same as audio out?I'm a little confused because it also says that if the tv doesn't have an audio out to connect the receiver to a vcr and use its tuner-wasn't planning on using my old vcr at all if I could help it. Thanks...
  2. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    Dennis,
    "Hi-fi" and "receiver" are often used interchangeably, so yes, you can connect your TV's "Audio to Hi-Fi" to your receiver.
    If you have a cable/satellite box, it would be better to connect the audio from your cable/satellite box directly to your receiver, especially if you don't intend to use your TV speakers.
    --Nathan
  3. Dennis Sr
    Jan 23, 2005
    11
    Thanks Nathan its up and running
