TV Stand
Discussion in 'Home Theater Projects' started by Clark Bradley, Aug 2, 2004.
  1. Clark Bradley
    Clark Bradley Stunt Coordinator
    May 2, 2004
    58
    I'm looking for a widescreen (16:9) stand for my Philips 30PW8402 (30"). Everything I see has two shelves but I'm looking for something with at least 4. All the entertainment centers are made for square tv's.
    Anyone know somewhere to buy this stuff online for a good deal? Recomendations?
  2. SimiA
    SimiA Second Unit
    Jul 26, 2004
    297
  3. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    4 shelves is tough on a short stand, you don't get much room between the shelves, some of the high end custom cabinets may work for you, but your probably going to be looking up at the set a little
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Please ask for specific advice about A/V accessories in this section. The Basics area is for general discussion at the beginner level. Thanks.
  5. Clark Bradley
    May 2, 2004
    58
    This is odd...I did post this in the basics area???
  6. Clark Bradley
    May 2, 2004
    58
    OK, how about one like this:
    [​IMG]
    I want something a little wider and maybe a little deeper. The height is about right.
  7. Clark Bradley
    May 2, 2004
    58
    Maybe I need to go more upscale...but I can't find anything that will hold a 16:9 TV.
  8. Dean_S
    Dean_S Second Unit
    Feb 4, 2004
    261
    I have a Salmander Twin 40 (www.mander.com) in walnut with walnut sides and mesh doors and 8 adjustable shelves (10 total if you include the fixed bottom shelf). It's a little taller then I think you want but they make a Twin 20 and 30 in shorter heights and they also now sell triple-wide stuff. Not cheap but very good quality and can hold a lot of weight. I was using this stand to hold my 40" CRT (300lbs) in my bedroom but I've moved and now that TV is in my living room its on a Boltz TVXL stand.
