TV speakers as center channel?
Discussion in 'Archived Threads 2001-2004' started by JasonKZ, Jan 4, 2002.
  1. JasonKZ
    JasonKZ Stunt Coordinator
    Dec 12, 2000
    191
    I was looking at the Sony 51 inch widescreen (KP-51HW40) and noticed that one of the features was that the there was an input for the center channel speaker on the TV so that the center would come from the TV speakers. Has anyone tried this? Would the sound quality be comparable to that of an average center channel speaker on top of the TV?
    Thanks!
  2. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Jason, I haven't tried this, but I would have to guess that a respectable, dedicated center speaker would be better than the one on the Sony TV. Besides, it is better to have a center speaker from the same product line as your mains for timbre matching.
  3. Scott Merryfield
    Dec 16, 1998
    12,055
    925
    In most cases, a TV's built-in speakers are of very low quality. You would be much better off running your receiver in "phantom center" mode than using TV speakers for your center channel.
  4. JasonKZ
    Dec 12, 2000
    191
    Thanks for your responses. The only specs I could find on the speakers on the SONY site were "Dynamic Acoustic Chamber (DAC) Speaker System (20 Watts x 2)" so you are right, 40 watts for a center channel would be pretty weak.
  5. MichaelG
    MichaelG Second Unit
    Jul 10, 2000
    322
    Like KeithH said, you really want all your speakers matched correctly, this makes a big difference for home theater. Try to find something that matches your L/R front's nd it will sound much better.
  6. Jim_Stu
    Jim_Stu Stunt Coordinator
    Dec 27, 2001
    134
    I thought you would never ask!!
    I actually have done it, and I am pleased with the
    results. However, I needed a pre-amp or a receiver
    with:
    1) Center channel equalizer
    2) Low level outputs for each channel.
    Receiver - Yam HTR-5280
    TV - WEGA 32"
    Main Speakers - JBL N38s
    Room size: 20 x 19 half of a 20 x 38 open space.
    I found out:
    1) TV amp 2/3 volume = 80db at 15 feet
    2) Equalizer is a MUST!
    JRS
