TV Problems, help...
Discussion in 'Displays' started by Chris Huber, Dec 26, 2003.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
    Ok, this is a ProScan 27 inch TV, S-Video with PS2 for a DVD player, that was purchased about 6 years ago. I have noticed something while watching TV here recently. All of the dark colors, shadows and dark scenes in movies have no deffinition or detail. They seem to be just a dark section that the TV can't get right anymore. It's nothing major because others haven't commented on it yet. I can see it though...
    Has anyone ever had this hapen to them? Is it a problem or am I just not seeing how movies are supposed to look?
    My buddies 25 inch Sanyo looks like it's a tad more sharp with a little more vibrant colors.
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Have you calibrated?
  3. Chris Huber
    Jan 2, 2003
    416
    How do I do that? I am new to TV tuning? Not sure what to do...
  4. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Try increasing the brightness. Also, can you darken the room a little?
    If you don't have a test DVD such as Video Essentials or AVIA, you can still experiment with brightness and contrast to see if you can make things look better. I still suggest that you try to keep contrast under 2/3 for a TV that old (under 1/2 for a new direct view tube TV).
    The test disks I named have a "gray scale" test where you can adjust the TV so all steps in the scale from black to white are distinguishable.
    Video hints:
