steveKlein
- Dec 20, 2005
I'm not exactly sure where this thread belongs if anywhere as this isn't really a dedicated home theater room problem; More of a "My house was built in the 2000s and the builders left a place above the fireplace for a TV to go, but it hurts my neck to look up at it" I was told by others that this would annoy me and I almost just picked a house with a different living room layout because of it. But to be honest, I didn't think it would be too annoying for me. I figured in time I would get used to it. Once I moved in, I put the TV in the niche and, it bothered me. It just felt too high. And to boot, there was nowhere to really put any of my equipment. I nearly cried myself to sleep the first night in my home because I thought I had made the biggest mistake of my life. Here is what the niche looked like the day I moved in:
But a little hard work and engineering yielded me a result that I am very pleased with. I built 2 brackets out of steel. One consists of 2 pieces sticking out from the top of the mantle/bottom of the TV niche connected by a crossmember. The other connects to the 8” tall piece of wood between the tile of the fireplace and the top of the mantle.
Once I got the steel plate built and mounted, I added a $70 tilting wall mount which I got off of Amazon.com and hung the TV. The stability is phenomenal. This setup could easily hold a much heavier TV. After running speaker wire through the walls and Ethernet cable from here back to my desk for a wired internet connection in the living room, the setup was complete.
Aside from the cable box, center channel speaker, and receiver which are visible, I also have a Slingbox and HTPC behind the TV. I also left an HDMI cable down there so I can easily hook up my Xbox 360 (or PS3) which permanently reside in another room in my house (yes, I have a mancave in addition to this ) The seating area:
If anyone has any questions about the specifics of how I built the mount, I will be more than happy to give you more details. It took a total of about 9 hours of labor to take the measurements, cut the pieces of steel, drill the holes, attach it to the fireplace, and mount the TV. About 2 additional hours to put in the 4 brackets that give the stands for my equipment support. These were also custom cut by yours truly. The next step? Add a quality subwoofer to match with my beautiful Ascend Acoustics Sierra-1 speakers (HTM-200s in the rear). After that? A 55” LED sure would be a nice upgrade over my 2007 model 40” LCD Thoughts? Suggestions? An enthused first time homeowner, Steve
