Tv->onkyo
Discussion in 'Archived Threads 2001-2004' started by Kevin Simon, Feb 8, 2002.
  1. Kevin Simon
    Kevin Simon Extra
    Dec 23, 2001
    22
    OK. I have a new WEGA FV-27FV17 connected to an Onky 575 with Mostercable Interlink (I think that is the model name) cables.
    I have to put the Onkyo on Max to get any kind of decent sound, even with the TV in "fixed audio" mode. And then I get hissing becausethe ONKY is cranked upso much. It is connected to the VIDEO1 in on the Onkyo.
    To give you an idea: With the TV the Onkyo is max at 75. When I play a DVD I usually play it at 60 for BOOMING sound. To get the same sound level with the DVD, and much less quality, it would be like playing it at 40 or so.
    Something MUST be wrong...I expected MUCH louder sound.
    Please help and thank you.
    Kevin
  2. Rick Radford
    Rick Radford Supporting Actor
    May 12, 2001
    642
    Kevin,
    My Hitachi variable audio output connects to my Onk 989's video 3 input via standard a/v cable. I set the MV to -20 under ref and then adjust the TV volume with the TV remote control.
    OTOH, my former JVC 32260 would not allow TV sound out of the TV outs until I turned off the TV speaker via the TV's menu.
    Hope this gives you an idea or two to try.
  3. Kevin Simon
    Kevin Simon Extra
    Dec 23, 2001
    22
    Ya, I turned off the TV speakers...Anyway, the sound on NBC, for the openning ceramony, was better last night. The low volumes are very apparent on Vh1/Mtv.
