TV interface for Winamp/Whatever
Discussion in 'Archived Threads 2001-2004' started by AaronD, Aug 30, 2002.
  1. AaronD
    AaronD Stunt Coordinator
    Dec 4, 2001
    234
    I've got an HTPC hooked up to a 27" VVega... I was wondering what everyone out there uses to playback MP3/SHN/whatever. I'm looking for an interface that will be readable on my TV.
    -Aaron
  2. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    Aaron,
    if you're connecting to your TV via composite/s-video (which I'm assuming you are, since I'm not aware of any HD-compatible 27" wegas), you're not going to find anything that will make it readable really. NTSC resolution just isn't sufficient for text display from a computer. There are a number of front ends out there, I just don't think any will be sufficient for what you are trying to do. if you were connecting via VGA output to a HD-compatible display it would be a different story.
  3. AaronD
    Dec 4, 2001
    234
    I don't have a problem reading the other text on my screen, it just takes some adjustment with the font sizes. Winamp however doesn't have the ability to change the font sizes, so double size mode has to fill in for that lacking... A few years ago there was an interface I saw for winamp and I can not locate it now. My Tivo is readable, other PVR's are readable, the HP mp3 thingy is readable, etc... It's certainly more than possible. It doesn't have to be for winamp, I'm open to anything. I just want to have it act like a juke box...
    Aaron
