I am having Samsung 55" H6400 (series 6) Smart TV with Samsung SMGHTH5550 Home theater system. Also having a STB with Dolby Digital.
STB does not have a Digital out (optical). It has only a SPDIF out. I have added a box which convert SPDIF out to Digital optical out & connected it to the Home theater. This Digital out & TV's Digital out both connect to the HT's Digital in through a (2 input & one output) box.
HT is connected to the HDMI (ARC) port on the TV & the STB is connected to the HDMI (STB) port of the TV.
Both TV & the HT is connected to the router via WiFi.
In TV's Speaker out there are 5 options available.
TV Speaker
Audio Out
Receiver
SoundShare
Multiroom Link
Earler the "Receiver" option was available & I could change the volume of the HT through the TV's remote. Now suddenly that option is un-selectable & only TV Speaker & Audio Out is available. How can I get the Receiver option back? (Anynet+ (HDMI-CEC) is enabled on both TV & HT)
Also the STB Dolby Digital channels can be heard only from front speakers of the HT. On HT under Audio there's an option with Digital output heading. It has 4 options
PCM
Bitstream (Unprocessed)
Bitstream (Re-encoded DTS)
Bitstream (Re-encoded Dolby D)
Sound comes from all speakers only if I select PCM from here. Why is that.
Please help me on this as I'm a newbie to this.
Thanks in advance.
(manual for the HT)
TV Speaker
Audio Out
Receiver
SoundShare
Multiroom Link
PCM
Thanks in advance.
(manual for the HT)
