I'm hoping someone more knowledgeable than I can help here:
I had an LG TV, connected via Toslink into a ZVOX 580. Worked great. Then about a year ago, I bought an SMSL M8 DAC to improve sound quality, worked flawlessly for 9 months. My girlfriend moves in, and her Sony TV (XBR55X800D) is larger, so I swap out the LG with the Sony, works straight away with the M8.
Then, the next day there is no sound and the M8 is saying No Signal. I check / reinsert cables, and finally get it working again, perhaps just a loose connection. Works fine again for a short while, then all of a sudden - no signal. It seems the input socket on the M8 might be loose as wiggling the Toslink cable in there seems to have some affect with the sound cutting in and out.
If I plug the Toslink cable straight into the ZVOX, works fine every time. I tried a different Toslink cable, same result. So, in thinking I might have a faulty M8, I exchange it for another unit, but this one also has the same issue. Hmmmmm.
So I just got hold of a Topping D30, but after connecting it, the abnormal signal light is on and the sound is just digital pulsing type noise.
I plug the Toslink cable back into the ZVOX - works instantly, back into the D30 - digital garbage. Swap out the cable, same result.
I feel like I'm missing something. I'd greatly appreciate any advice!
