TV-Color Temp?
Discussion in 'Archived Threads 2001-2004' started by Carlos_A, Aug 21, 2002.
  1. Carlos_A
    Carlos_A Auditioning
    May 27, 2002
    7
    I have a Sony Wega 27 inch analog and a 32inch HDTV Sony XBS.
    Now....
    I would like to whats an ideal Setting for "Color Temperature" when view a Movie?
    -thanks for any advice!!
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    XBR? I leave the color setting "normal" and use the "movie" setting for DVDs, with this setting calibrated using Video Essentials, and I would highly recommend doing this for yours using VE, Avia or Sound & Vision HT Tune Up.
    Color temp is not specifically related to movie viewing, but rather is a shift to either blue or redish-brown tint in the greyscale. Personally, I think it looks funny with both of them.
  3. James Brown
    James Brown Stunt Coordinator
    Jul 18, 2002
    89
    I keep my wega at Warm and Movie at all times.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i keep mine at whatever the middle one is. i know it's not movie and it's not the torch mode one either.
    i think i read somewhere that middle one is pretty close to the 65000k standard.
    i then base all my calibrating from that setting.
  5. Carlos_A
    May 27, 2002
    7
    On my "Movie mode" for the analog Tv it's set to Warm.. I kind of left it alone since I bought it.
    As For XBR, I use "Pro Mode" when view a movie, which is set on Cool. If I were to set it on Warm. The picture definition become Clean and smooth but its too Redish[​IMG]!!
    I guess I really need to get calibrated.
    btw...Which Calibrating disc would you guys recommend I buy? (I'm willing to spend $40.00 - $60.00 if needed)
  6. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    Carlos, actually the cool setting from what I've read is very hot. From what I understand it pushes the contrast & blue up quite a bit. You are better off using the normal setting. For the red there are a couple of adjustments you can make in the service menu to fix it, BUT this is something I would not even consider if you are not completely positive about what you are doing or you can kill your set.
    I have a 36" Sony XBR & have done a few things in the service menu & I feel like I got a new TV all over again.
