TV audio out
Discussion in 'Archived Threads 2001-2004' started by MikeMeehan, Dec 27, 2002.
  1. MikeMeehan
    MikeMeehan Stunt Coordinator
    Oct 31, 2002
    51
    I don't know if this is the right place to ask but here goes.I want to hook up a gamecube straight to the tv's audio video inputs(sony wega)and use the audio out to my receiver(h/k225).will the receiver be able to decode the DPL2 if the audio is coming from the tv's audio out? Thanks for any advice on this.:)
  2. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    I have mine hooked straight up to my receiver and it decodes fine. I would figure that since the information to the right and left channel does not change it would work just fine. If you have rogue squadren 2 try the audio test with your setup.
  3. ChristopherBer
    ChristopherBer Stunt Coordinator
    Dec 23, 2002
    74
    If you hook the Gamecube to the Sony and then audio out to the reciever it should decode Pro Logic II.
  4. MikeMeehan
    Oct 31, 2002
    51
    Thanks guys.I want to hook it up this way to make it easier for the kids so they don't have to use the a/v receiver.
