Abby
Grip
- Jun 13, 2003
Way back in 2003, I think, I asked for advice on a speaker system and bought a Sony STR-DE595 receiver and JBL speakers. Well now I'm back for advice on a new TV and blu-ray. My dvd player can't play discs it was playing the night before and I can't hit my TV to get the screen to come back on anymore so I think it's time to update. I've got an affection towards Panasonic, though I'm not glued to it. I am leaning towards a Panasonic DMP-BDT210 and a 42" Panasonic TC-P42ST30. My questions are about TV size, hook-up, and the center speaker. 1. The attached photo is a to scale model of my "theater room". I've made a scale model of the 42" TV and put it on a table I use as a TV stand. The two bookcases (brown) on either side are short but they may limit the placement of the TV. Now, I could put a box under the TV and get a 46", but I wonder if I should bother. Money isn't really an issue, but the room is small and I'm used to a 27" 4:3 tv, so a 42" would be bigger than what I've got now. I'm not thrilled about mounting the TV to the wall, don't want holes in the wall. Oh, I'll also mention I'm near sighted and like to sit close, hence the chair in the middle of the room. Thoughts? [ATTACHMENT=178]Theatre Room.jpg (52k. jpg file)[/ATTACHMENT] 2. My receiver does not have an HDMI jack, so what would be the best way to hook up the audio? I've been using the Digital Audio *edit* Digital Optical. 3. And finally, where do you put the center speaker with a flat panel? Currently, my JBL S-Series center is on top of my 27" TV (yes, there are green spots over the tv's speakers, but unless I'm watching Due South, I rarely notice them.) Do you put it below? How close can it get? Thanks so much for your time.
