Turntable Recommendations?
Discussion in 'Playback Devices' started by Andy_Munich, Feb 7, 2005.
  1. Andy_Munich
    Andy_Munich Stunt Coordinator
    Jul 5, 2002
    108
    26
    10
    My user ID is a clever riddle!
    I need some help! I told my girlfriend if she wanted to keep her LP's then she had to properly store them in a more attractive manner than the stack of unsightly boxes hiding in the corner from when we moved in around NINE months ago ...
    so she took them all out, cleaned them before placing them in archival sleeves and filed them neatly away on the bottom shelves of our bookcases. The problem is that now we need to purchase a decent turntable for her vinyl that does not cost an arm and a leg?
    Any suggestions?
  2. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    Andy - define 'arm and a leg' [​IMG]
    What might your price range be?
    Does your receiver (or pre/pro or whatever) have a 'phono' input. If not you will probably need a phono pre-amp as well.
    Same questions for phono cartridges - how much are you willing to spend?
  3. matthewRaz
    matthewRaz Stunt Coordinator
    Jan 25, 2005
    68
    i got a pro-ject debut II turntable a few months ago for about $400 cdn. simple, pretty and sounds great. my old stereo receiver has a phono stage though. they come in glossy color finishes for a bit more. i think urban outfitters (trendy clothes and home stuff) sells them for $300 amer. on their website but they (pro-ject) have the sonic goods for a great price
  4. Andy_Munich
    Jul 5, 2002
    108
    26
    10
    Sorry for the delay in replying ... out of town house guests ...
    Anyway - in the $400. range would be nice and as it has been ages since she has purchased a cartridge, I have no idea.
    As far as hook-ups, our Denon is good to go.
    And thanks for the help [​IMG]
  5. matthewRaz
    Jan 25, 2005
    68
    $400 would get you the step up pro-ject "xpression" or the goldring "gr-1" - both are supposed to to be outstanding budget tables
  6. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Don't mean to hijack this thread, but I'm in a similar boat, and didn't want to start an identical thread. I've been living with my parents old Sony table for a year or so, and now that I've got some cash-flow happening, I'd like to replace it. Would $300 for the table + cartridge get me anything decent?
  7. Andy_Munich
    Jul 5, 2002
    108
    26
    10
    Anyone else out there have ideas for Matt? There has to be some vinyl lovers out there still, eh? [​IMG]
  8. Scott_N
    Scott_N Second Unit
    Jan 22, 2003
    425
    You could get a Music Hall MMF-2.1 in that price range. It's a nice table and comes with a factory mounted cartridge. Needle Doctor and Music Direct sell it or you may have a local dealer. You could also look on ebay or Audiogon for a used Music Hall MMF-5 or a Rega P3. Good luck with whatever you choose!
  9. Jim Rakowiecki
    Jim Rakowiecki Stunt Coordinator
    Sep 2, 2003
    162
    check for a used Dual 505. A decent example can be had for around $150.00 and spend a another $150.00 on a cartridge and you'll be all set.
  10. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    ditto scott on the rega and music hall recommendations.
    here's a thread i posted ages ago ... may still find some useful info in there.
  11. Jack Keck
    Jack Keck Second Unit
    Nov 23, 2001
    269
    I have a Rega P2, myself. I haven't listened ot different brands, but can stronly suggest that you get the best TT you can. I had the same cartridge mounted on the Rega as on my previous TT (Phillips GA-312, not a bad table, either) and could not believe the difference in the sound from just the better TT. I never noticed music coming from outside the speakers before!
    So don't skimp on the TT!
  12. Don Black
    Don Black Screenwriter
    Dec 11, 1998
    1,480
    I'm in a similar boat with a $250-$400 price range. But I need an entry-level turntable (w/ cartridge) that has RCAs out so that I can plug it into my Sonos system. Any recommendations would be appreciated.
    The Music Hall - MMF 2.1 Turntable looked perfect but I couldn't see any RCA outs listed under its product specs.
  13. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    don -
    afaik, all turntables use rca outputs .. or am i missing something?
  14. Scott_N
    Scott_N Second Unit
    Jan 22, 2003
    425
    Don
    The 2.1 has rca outputs.
    Ted
    There are phono cables with XLR outputs but these are usually expensive aftermarket cables.
  15. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If you want to go pro, then the Stanton line of turntables might be worth taking a look at. They're usually discounted about 50% (local Guitar Centers and other pro shops) and some models have digital outs.
  16. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    duplicate post.
  17. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    If you can find a used Music Hall MMF-5 (or MMF-2.1 for Matt) in your price range it would be a pretty good deal. The stock Goldring cartridge is not bad, but the table can be upgraded very inexpensively and by a considerable margin by replacing the Goldring with an Audio Technica 440ML. The 440ML is faster and has better bass response than the Goldring 1012 it replaced in my MMF-5 and it also tracks better, when properly set-up. You can find the AT-440ML for under $100 from The Needle Doctor.
    Usual disclaimers, this is MO, YMMV, etc. I have no affiliation with TND, except as a satisfied customer.
