Tumults: Shipping again?
Discussion in 'Archived Threads 2001-2004' started by Seth_L, Mar 12, 2003.
  1. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    Kyle or Dan,
    Were the voicecoils that were sent to the build house yesterday (3/11) satisfactory? If so when will the remaining drivers ship? If not, what's the plan of action?
    Seth
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    We should probably have a separate "Tumult Shipping?" forum.
    Have you tried calling Adire? Dan answers the phone lots of times.
  3. You could always visit the Acoustic-Visions Forum. There is a shipping thread in there. Dan does visit that forum.
  4. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  5. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    If it makes you feel any better, one of my two Tumults arrived with 3 of the spokes broken away from the mounting flange! [​IMG]
  6. Damn!!!.....A UPS "handler" must have ruptured a disk and dropped the driver while loading it onto the truck...who knows. How does the package look?
  7. Brian Bunge
    Sep 11, 2000
    3,716
    Tony,
    There's a big hole in the side of the box. The other one appears to be fine, thankfully. I've already called Adire and left them a message and called UPS to start the process.
  8. Greg Yeatts
    Greg Yeatts Second Unit
    Feb 26, 2002
    300
    Brian
    I am countersinking my Tumult. Do you think a 15.125 hole is big enough for the countersink? I was hoping to use one of the PE cast frame .25" driver mounting kits, but the holes in the gasket look kinda small. OTOH I am afraid to use anything other than the .25" cast frame mounting kit. This thing is a monster. The pics you've seen don't prepare you for the mass of the thing.
    Don't have too hard of feelings for the UPS guy, I thought I would need a truss after moving mine around. [​IMG]
  9. Greg, I had the BPD1503 and it has the same gasket TTBOMK, and I had to use the 10-32 kit. I had a downfiring driver, and even with gravity working against the bolts, they held up just fine. Get the 10-32, not the 1/4" when using the gasket. I also used tiny washers between the bolt head and the frame to give a more distributed force on the frame.
  10. Martice
    Martice Screenwriter
    Jan 20, 2001
    1,077
    Hey Brian, if it makes you feel any better Chris Tsu Tsu predicted what happened to your Tumults.
  11. Martice
    Jan 20, 2001
    1,077
    Hey Brian, if it makes you feel any better Chris Tsu Tsu predicted what happened to your Tumults in a earlier post.
