Jeffrey Stanton
- Feb 25, 2003
Howdy folks:
Could someone suggest a few BFD filters to apply to these measurements I took (uncorrected) for my sub (see below)? I notice there's a couple of nasty peaks centered around 48 and 80 Hz. Looks to me like they're about 15 dB above the rest of the curve...
During testing my KSW-15 sub was running also (off of the center channel) along with the above LFE sub, so I'm sure it is probably contributing somewhat to those peaks. Which begs the question: Shouldn't I be EQing both subs individually to "FLAT" rather than EQing my LFE sub with my other center channel sub on and running also?
I have a BFD and a Behringer DSP-8024 Ultra Curve Pro I can use.
Here's the measurements I took, I started at 10 Hz (set at 75 dB):
10 Hz--75 db
12.5 Hz--77 db
15 Hz--77 db
17 Hz--78 db
20 Hz--79 db
22 Hz--79 db
25 Hz--78 db
28 Hz--78 db
32 Hz--79 db
36 Hz--80 db
40 Hz--95 db
45 Hz--95 db
50 Hz--95 db
56 Hz--87 db
63 Hz--77 db
71 Hz--91 db
80 Hz--95 db
89 Hz--95 db
100 Hz--87 db
112 Hz--80 db
126 Hz--84 db
142 Hz--85 db
160 Hz--68 db
201 Hz--68
Jeffrey Stanton
10 Hz--75 db
12.5 Hz--77 db
15 Hz--77 db
17 Hz--78 db
20 Hz--79 db
22 Hz--79 db
25 Hz--78 db
28 Hz--78 db
32 Hz--79 db
36 Hz--80 db
40 Hz--95 db
45 Hz--95 db
50 Hz--95 db
56 Hz--87 db
63 Hz--77 db
71 Hz--91 db
80 Hz--95 db
89 Hz--95 db
100 Hz--87 db
112 Hz--80 db
126 Hz--84 db
142 Hz--85 db
160 Hz--68 db
201 Hz--68
Jeffrey Stanton
