Seth_L
- Apr 5, 2002
First I was all set on a BP 1503, and then changed my mind to the Tumult, but now that I've modeled what two Stryke AV 15" drivers will do I'm wondering if I should change my mind again.
I'm looking at 200L enclosures with 4 Adire PR15s. Now, my question is which one of these designs is better. They're a bit different from each other. The Stryke setup will clearly play louder at higher frequencies, but rolls off sooner though not as severe. The Tumult holds it's response at a lower volume to very low frequencies, but drops like a rock. I would think that the Stryke setup would do better in most rooms where there is at least some modest gain that low and the Tumult would do better in rooms where there flat out is no room gain. Since most rooms have some gain (at least enough to flatten the Stryke design to 20Hz) I presume I would be better off building it rather than the Tumult.
Here are the two response curves from Unibox 4.02.
Link Removed
Link Removed
Any comments or suggestions are welcome.
Seth
Link Removed
Link Removed
Seth
