Tube CDP and SS pre (1 Viewer)
Nico
Hi Guys,
I am planning to get a tube CDP, and hook it up with an SS pre-amp. My question is would this setup work out well? Would the tube sound coming out be overridden by the pre? Or do I need to get tube pre instead? I would appreciate your help.
All the best.
Nico
Saurav
No reason why it wouldn't work. Don't worry about SS sound overriding tube sound or vice versa.
Martice
Welcome to the forum Nico. I used to run a Sonic Frontiers Line 1 tube preamp with a SS amp and loved it. I thought about using a tube CD player but I decided to go with the tube preamp instead because I wanted everything to come across on the warm side from CD to my Mini-disc player I used to own. If you haven't already, you can go to sites that seem to favor 2-channel or at least the audio aspect of home entertainment for a lot of tube preamp input or do a search for tubes on this site and you may find some input as well. However, I think it would be more information at the two links than on this site.
Check these sites out:
Audiogon Discussion board
or
Audio Asylum
Good Luck
Nico
Thanks for the reply. I was thinking to get a tube pre-amp (Sonic Frontiers is nice :)) but I am going to be using my system for double duty as far as Music/HT. With a good all-around pre (like maybe Outlaw's new pre), I don't have to switch back and forth between music/HT. My amp will be Odessey Stratos. The CD would likely be Norh CD-1/QDS-15 (risky buy).
Can you guys recommend some good all-around (HT and music) pre under $2000 (besides outlaw)? What are some great tube CDP?
Nico
Martice
Here are a few tube CDplayers:
http://www.amchome.com/index.php
Here is a post from Audiogon with a similar request to yours:
__________________________________________________ _________
Any good tube CD player under $1000 ???
I am using Jolida amp, and Cabasse 4ohm skiff 302 !!
by Mkchan40 on 04-29-02
Follow ups
Good tube CD player beside AH & Heart ??
Audionote players are superb!
Meby 04-29-02
There should be a CJ tube cd player in that price range-my friend used to have one I believe it was a DV-1B or something like that(it was a while ago that he had it), but for the money it was a great player(he recently sold it for around a grand, so it would be worth looking into.
~Tim
Tireguy 04-29-02
Link Removed has a CJ dac on sale for 1200 (under "special promotions"). But you would need a transport. A nice unit.
Tom
no connection to the shop, just an occasional visitor
Tacs 04-29-02
Take a look at the Anthem CD-1
S7horton 04-29-02
The new Jolida tube upsampling cd player will soon be tested at the TNT website....they have it in house now so a review is to follow. I think it is selling around 900US...This may be interesting for you as you already have that brand in your system....
Bluenose 04-30-02
I have been reading about players from Cayin and QDS(Norh OEM) for around $500 that are suppose to be wonderful. But I personally have never heard either one.
Meby 05-12-02
I have the Cayin CDT-15A and I love it. :) $510 USD plus freight from China. The chinese factory also makes Audio Electronic Supply (AES) amps.
Jayel
Jarthel 05-13-02
Jarthel....have you had a chance to compare the Cayin CDT-15A to any other players yet? Just wondering what level it compares to or with? AES is "good stuff"...good listening
Bluenose 05-14-02
__________________________________________________ __________
I hope this has helped.
eathree
