Tube Amps
Discussion in 'Archived Threads 2001-2004' started by Samuel Des, Sep 28, 2001.
  1. Samuel Des
    Samuel Des Supporting Actor
    Feb 7, 2001
    796
    I've been considering purchasing the Antique Sound Lab Wave AV-8 tube amp to power my NHT SuperCenter. I am hoping that the tube amp's reputed warmth will help remove my occasional sibilance problems. But I wonder whether mixing solid state (HK AVR 7000) with a tube amp will produce "awkward" results. The AV-8 seems inexpensive enough for me to experiment, so I may simply purchase it. Anyone try a similar experiment?
    Best, Sam
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    I seriously doubt the AV-8 will be adequate to the task of powering an NHT speaker in a Home Theater environment.
    With 8-10 watts of output power, you wouldn't be able to drive the speaker very loudly at all.
    John Kotches
    Contributing Writer
    Secrets of Home Theater and High Fidelity
  3. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Go to www.audioasylum.com and search through the Tube Asylum archives. There have been several discussions on SS pre/tube amp combinations, as well as the other way around, and the pros and cons of each. If I remember correctly, I believe the issue is primarily impedance matching - check the input impedance of the AV-8 and out output impedance (on the preouts) of your receiver, and makre sure they differ at least by a factor of 10. The more the better.
  4. Ken Situ
    Ken Situ Stunt Coordinator
    Aug 6, 2000
    102
    You can always search on ebay, and buy a mono-block Dynaco Mark IV for about $100.00, and I think it will be more than enough for your center channel.
  5. Samuel Des
    Feb 7, 2001
    796
    Great resource, Saurav! Thanks for the info, guys. [​IMG]
    Best, Sam
