I received this receiver some years ago from a friend who said it had broke and he didn't want to try and fix it. It "might" have been damaged due to power issues during a storm, but I don't recall anymore the exact thing he said might have led up to the issue.
I've had it sitting around the house for a while on my list of projects to get to at some point, and the time had finally come. I already had found the user manual and "service" manual only - this has the schematics, board layouts and parts lists...but no real troubleshooting or service advice in there. After looking everything over the last couple of days and taking some measurements, I found that one of the ICs on the amplifier board was not getting supply voltage. The fusible resistors R4397 and R4398 were open, and that leads me to believe that IC4301 (for the surround channels) has failed. No other components seem to be an issue (no bulging capacitors, no visually overheated components), and the B+ and B- supply voltages were making it to the other similar ICs (4201 and 4101 - their fusible resistors were also OK).
As all 3 of these ICs feed in to whether to activate the PROTECTOR! mode, so I think that this is a likely culprit and a good place to start to try and make a repair.
I read through all of this achived thread here to try and find a resolution to a similar issue, but the final outcome was never posted:
www.hometheaterforum.com
I will post my findings - good, bad, or frustrating - as I try and fix this receiver.
It happened! PROTECTOR mode on my Sony STR-V444ES!
I was away for a few days for the Memorial Day weekend, and like every time I go away, I had all my A/V components unplugged from the outlets. Perhaps this seems odd, especially since I use surge protectors, but I lost a computer to an electrical storm last year, and I don't take any chances...
