Brad Russell
- Aug 13, 2003
I just bought a Toshiba SD-4900 thinking that it at least gets me into DVD-A and will eventaully go upstairs when replaced by a better piece. But I'm confused about the whole 24/96 thing. I have it currently connected to a Yamaha A-1 buy a digital coax connection. The A-1 can only handle 48k. Would I be better off to hook up the analog outputs of the Toshiba and set it to 96? And can regular old CDs take advantage of the higher resolution or do you need special CDs? I guess I'm suspicous that an $80 DVD player has better DACs than the A-1.
Thanks!
Brad
Thanks!
Brad
