james e m
- Jun 3, 2001
I will be getting married in Dec. and I am looking to buy a new TV set. I’m thinking of either getting a 36” TV or a “cheaper” HDTV because I am eventually planing to go the FPTV route. So this will be my sort of “in between” TV until I can afford the FPTV set up. After I get the projector, the TV/HDTV will be used for casual TV watching. My questions are:
1. Would you recommend spending the extra money on an HDTV now or buy a 36” TV and put the money I saved by buying a non-HDTV towards a projector.
2. Can somebody recommend a relatively inexpensive HDTV that I can do some research on? I’m looking for one with a wide viewing angle.
Thanks!
James
Thanks!
James
