troubleshooting dead sub.
Discussion in 'Speakers' started by Bobby_K, Dec 12, 2005.
  1. Bobby_K
    Bobby_K Extra
    Jun 2, 2003
    16
    i used a lousy cambridge soundworks powered 10" in my first ht setup. when it died, I didn't bother looking into it, I just upgraded.
    now Im thinking of reviving it as a second sub in my setup. It just stopped producing sound one day, it didn't die during use, I just turned it on one day and nada. The fuse is good, and the power LED is on, the sub itself is not damaged per say, it moves air properly when I pump it with my hand, its not blown out, seems to be an electrical problem of sorts. Where is the best place to look first?
    I will probably open it up and see that a lead wiggled loose :b but I figured some knowledge passed on would be helpfull before I dive in.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    The best / easiest thing to do is to find a cheap external amp, by-pass the failed amp, and wire the external right to the driver.
  3. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
