Trouble with Pluge---DVD player or Projector?
Discussion in 'Archived Threads 2001-2004' started by Daniel_M, Feb 5, 2002.
  1. Daniel_M
    Daniel_M Stunt Coordinator
    Mar 15, 2001
    60
    I'm reposting this from the DVD Player
    forum in the hopes of more feeback.
    Any info would be appreciated. Thanks.
    Dan
    >I recently tried to do a video lineup
    with the Video Essentials DVD and
    had trouble with the pluge test. I could
    not see the "blacker than black" test signal.
    With the DVD came a notice which said........
    "The established method for setting the brightness
    control as described in Video Essentials requires
    a stripe of picture information that goes below black.
    Even though such image information is encoded and
    preserved in this DVD, most FIRST GENERATION players
    are not capable of repoducing it."
    My question is: does anybody know if the Sony DVP-S7700
    is considered a first generation player?
    (a repondent in the other forum says it isn't but
    that doesn't mean it will resolve the V.E. pluge test)
    I have a Sony CRT front projector which is highly
    accurate and I have noticed on some films a loss
    of information in dark areas that cannot be resolved
    by adjusting brightness or contrast, same with the
    V.E. pluge test.
    Time for a new DVD player?
  2. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    The Sony 7700 is a second generation player. The 7000 was the first generation model.
    Try going into your DVD player's setup menu and turning the "Black Level" on. I had to do this on my Sony 9000ES to see the moving black bars on the Avia brightness pattern in interlaced mode.
    You'll have to recalibrate after you change this setting, but then it looks like you're trying to do that anyway!
    KJP
  3. Daniel_M
    Mar 15, 2001
    60
    Kevin,
    I don't think the 7700 has that black
    level adjustment in the setup menu.
    I've been through the menus and the
    manual again and can't find any mention of it.
    Are you sure it's available in my model DVD player?
    Dan
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    The 7700 is a second generation player. I believe Video Essentials has a procedure for setting the black level despite the DVD player not being able to produce blacker than black. I am not sure about AVIA. Anyone?
  5. Daniel_M
    Mar 15, 2001
    60
    Neil,
    Yes V.E. does have an adjustment
    when you can't do the pluge test properly.
    Trouble is, it's really only a half measure
    and doesn't fix the problem of crushed blacks
    in the films I'm watching.
    From the responses in this and other forums it looks
    like the problem does originate with my Sony DVD player.
    Thanks to all who replied to my original
    question.
    Dan
