Rob Landolfi
- Feb 26, 2002
I'm having a heck of a time with an IE Script Error that happens when a program of mine opens up a web page window to look at items on eBay, and wanted to see if you had any thoughts.
I've been searching all over the web and have tried IE settings such as "Disable Scrip Debugging (check mark)" "Display a notification about every scrip error (unchecked)" and registry settings in IE such as "DisableScriptDebugging - yes". A typical message reads:
"An error has occurred in the script on this page.
Line: 111
Char: 2
Error: 'Document.Referrer' is null or not an object.
Code: 0
URL: (website code)
Do you want to continue running scripts on this page?"
I've also reinitialized a few regsvr .dll files and nothing is working. I've scanned for spyware and cleaned up with AdAware, SpyBot and Bazooka.
Nothing seems to work. About 4 or 5 IE Script Error Windows will pop up successively as I click to close them before I can properly view my page. Crazy thing is that when I installed Mozilla a month ago, these error messages went away even though this program uses IE to view pages on eBay. The error messages came back this week, and they really make the program unusable. I have the program on my laptop as well, and (fortunately) don't get the error messages there. As I type this, a change I made this week comes to mind… I installed Norton SystemWorks 2005 Premier. Maybe something in there is causing me trouble, and it's not on the laptop yet. However, I had SystemWorks 2004 on both computers (errors on desktop; laptop runs program fine), so that may not be an issue.
If only there was a way to truly disable the displaying of these messages as they come up in this program I'd be set. I never see anything like this when browsing eBay (or anywhere else) in Mozilla or IE, only when this program (SnipeRight) accesses the web. Thanks for any insight.
Line: 111
Char: 2
Code: 0
URL: (website code)
