Bull
Grip
- Dec 20, 2007
- Dan Bullard
I have been having an issue with my system, first of all, I have a Optoma HD80 projector, I also have a high def cable box and a onkyo hr800 reciever, the problem I am having is all my channels that show in high def are in the 200 to 295 channel range, when viewing these channels the screen will have serious latency issues as in freezing and moments later return only to freeze again, now if I go to the lower channels which are not broadcast in high def, I got no problems what so ever, I also have my projector hooked to a PS3 with no trouble, The PS3 is hooked with a HDMI cable and optical audio, The cable box is hooked thru the receiver with composite cables that also run to the projector, Tonight I will try to isolate the trouble by hooking the projector directly to the cable box, This system has been working fine for several months, I also viewed the high def channels on my plasma screen in another room with no trouble's at all, I'm thinking my receiver is the culprit, any idea's on this,
