Triwiring Def Tech CLR-3000
Discussion in 'Archived Threads 2001-2004' started by Sammy Sams, Oct 28, 2002.
  1. Sammy Sams
    Sammy Sams Agent
    Sep 14, 2002
    30
    This speaker has a hi, mid, and lo terminal and wondering what you all recommend for triwiring in terms of cable brands and where to purchase at a reasonable cost. Thanks
  2. John H
    John H Second Unit
    Nov 27, 1998
    472
    Tri-wiring the speaker would offer no improvement. The C/L/R 3000 uses an internally powered woofer section. When feeding it a speaker level signal it converts it to line level before feeding the amplifier.
    I would remove the jumpers between the mids and lows and feed the low level RCA input a "full range" center channel preout signal if possible.
  3. John Doran
    John Doran Screenwriter
    Jan 24, 2002
    1,330
    6
    110
    sammy,
    i'm not sure if the (in my opinion, vanishing) returns you'll see from tri-wiring would warrant the expense. although, depending on the wire you use, it wouldn't really cost all that much.
    i've bi-wired mine and can't really say if there's any audible improvement; i'm in the "even-if-it's-not-any-better-it-certainly-can't-be-worse" school of tweaking.
    anyway. best way to go is try it for yourself and see (hear) what you think.
    - jd
