Kevin. W
- Oct 27, 1999
Just curious if anyone could give some feedback on the Trippe Lite LCR2400. It seems to do the same as the Monster AVS2000 but at a fraction of the cost. definitely has the power output to handle a hungry HT. Here's a link.
DESCRIPTION
Tripp Lite's LCR2400 automatic voltage regulation system offers complete protection from brownouts, overvoltages and transient surges in a convenient rackmount format using only 3 rack spaces (3U). Transformer-based voltage correction circuits maintain usable 120V nominal AC output during brownouts as low as 87V and overvoltages to 140V. Network grade equipment protection offers AC surge and noise suppression. Supports heavy loads up to 2400 watts. Includes 14 NEMA5-15R output receptacles (2 front, 12 rear), 12-ft. line cord and 7 diagnostic LEDs that display incoming voltage level. $25,000 Ultimate Lifetime Insurance (USA & Canada Only).
KEY BUYING POINTS
Maintains usable 120V nominal output during brownouts as low as 87V and overvoltages as high as 140V
2,400 watts output power rating supports heavy 120V loads up to 20 amps
Convenient rackmount format uses only 3 rack spaces (3U)
Compatible with 2 or 4 post 19 inch rackmount applications
Network grade surge suppression
Complete EMI/RFI noise filtering
7 diagnostic LEDs indicate input voltage level
14 protected NEMA5-15R output receptacles (2 front / 12 rear)
12-ft. AC power cord with standard NEMA5-15P input plug
2 year manufacturers product warranty
$25,000 Ultimate Lifetime connected equipment Insurance (USA & Canada Only)
TYPICAL APPLICATIONS
Maintains usable output voltage during severe brownouts and overvoltages in 19 inch racks for network, telecom, A/V, live sound and other applications.
PACKAGE INCLUDES
LCR2400 Line Conditioner
Mounting hardware
Instruction manual
COMPLETE SPECIFICATIONS
Output VA / Watts 2400VA
Nominal Voltage / Frequency 120V / 60Hz
Input Voltage Range 87-140V
Output Voltage Range 106-132V
Cord Length 12 ft. / 5.4m
Outlet Quantity / Type 14 NEMA5-15R (2 front, 12 rear)
AC Surge Suppression 1440 joules
EMI/RFI Suppression up to 80 dB
Front Panel LEDs 5 LEDs show incoming voltage status
Dimensions - H x W x D (in.) 5.25 x 19 x 5 (hwd/in.)
Form Factor Standard 19 inch rack mount format using 3 rack spaces (3U)
Material of Cabinet Construction Steel
Shipping Weight 27.00 lbs. / 12.25 kg
Product Warranty 2 years
DESCRIPTION
KEY BUYING POINTS
PACKAGE INCLUDES
Mounting hardware
Instruction manual
