Tributaries Vs. Monster........
Discussion in 'Archived Threads 2001-2004' started by Roque_A, Apr 19, 2002.
  1. Roque_A
    Roque_A Auditioning
    Jul 18, 2000
    8
    Hi all I need some advice. I'm currently running Monster Video 2 and I want new cables because these are old and decrepit. I'm looking at either the Tributaries Delta line or the Monster video 3. I can get both of them for about $60. I want your honest opinion on which I should buy. By the way it is a 2meter length. Thanks in advance for all your help.
    Roque[​IMG]
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I don't think you will go wrong with either of the cable lineups you mentioned.
    Somehow, if it were my theater, for a 6-1/2 foot (2 meter) cable or cable set I would buy from Radio Shack or any of the mass merchandisers like Circuit City what they would call a medium grade video cable. For progressive scan, to play it safe, at least the Y cable should be HDTV rated.
    Video hints:
  3. Chris_Freeman
    Mar 15, 2002
    25
