Transponder Selection
Discussion in 'Archived Threads 2001-2004' started by Dave Barretto, Oct 23, 2001.
  1. Dave Barretto
    Jun 12, 1999
    37
    Just a general question:
    On setting up a system: on the menu screen you have an option of selecting the number of a transponder? How does this effect the Bird reception? What are the different transponder numbers used for?
  2. Larry Schneider
    Larry Schneider Second Unit
    Aug 9, 1999
    356
    Each transponder carries a number of channels, 5 or so, so whatever channel you input involves automatic switching to the correct transponder. You can change transponders manually while checking your signal strength.
  3. Dave Barretto
    Jun 12, 1999
    37
    Larry
    Thank You for the information --
  4. James Reyes
    James Reyes Stunt Coordinator
    Jul 24, 2001
    66
    When pointing a dish it is best to set the receiver to the home transponder. IE if you are pointing to EchoStar 119 set the screen to transponer 1.
    James Reyes
    www.libertyforums.com
