transponder intermittant
Discussion in 'Archived Threads 2001-2004' started by Mike Tondreault, Dec 23, 2001.
  1. Mike Tondreault
    Mike Tondreault Auditioning
    Dec 17, 2001
    14
    Hey guys. I just changed my multiswitch from a 4X2 to a 4X4 to accomodate adding a Tivo. My problem is now I get perfect readings on some transponders and 0 on others. I need to know in ya'lls experience, is this a bad switch or was I clumsy and knocked the dish out of alignment. It is a high def dish and directv was no help. I am getting some channels on all three boxes, but not all of them. TIA for your help.
  2. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    If you're getting a signal on even transponder numbers but not on odd transponder numbers, or vice versa, check your cable connections. If all three receivers are affected then it's probably a cable problem between the multiswitch and the dish.
  3. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
    I've had this a couple of times on my Sony T-60 (DirecTiVo). It seems that the problem was with the box itself as the reboot has fixed it every time.
    --Dmitry
  4. Mike Tondreault
    Dec 17, 2001
    14
    Thanks for the help guys. It appears that this multiswitch input wiring was different from the other one. Hence, me wiring it incorrectly. I got it figured out and working now. I just need to figure out how to activate the second tuner in my satt60 now. Again, sincere thanks for the replies.
  5. Dmitry
    Nov 30, 1998
    740
    Mike, to enable the second tuner you need to go through the satellite setup again. That is assuming that you have software version 2.5, if it's earlier than you'll have to wait till your box downloads it.
