Transparent (neutral) amps
Discussion in 'Archived Threads 2001-2004' started by scott cerv, Jul 31, 2002.
  1. scott cerv
    scott cerv Stunt Coordinator
    Mar 26, 2002
    51
    I'm looking to be powering a Diva 6.1,4.1,c3 setup in a couple months so I want to go listen to some amps. Don't have it yet, but I will more than likely be using a 3802 until I find an amp and then use the preouts until I find a used AVM-20.
    As the Diva's are nice and laid back, I don't want a laid back amp. I'm possibly looking for something neutral, but it could also be slightly forward, slightly. In the future I might get the CDM9NT's as well so I'd like something that would complement them as well. Any suggestions?? I've taken a look at the reviews on the Sherbourn and that looks like a nice unit.
    SC
  2. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    WARM: Krell, B&K, Rotel, Parasound, Conrad Johnson, Marsh Sound, Marantz and Denon Separate amps.
    NEUTRAL: Proceed, Mark Levinson, Krell FPB, LLano Design, Theta.
    BRIGHT: ATI, Outlaw, Adcom (multi channel), Bryston (brightston[​IMG]), Cinepro, Cinenova.
    These are some that come to mind that I have listened to. I dont have any experience with Sherbourn so I can't comment on it.
    Your best bet would be a Rotel. They have a slightly rolled upper end but not laid back like some of the other warm amps. Also Rotels mate well with B&W, so you should be set with your speaker upgrade too.
    Best of luck.
  3. dpippel
    dpippel HTF Premium Member
    Feb 24, 2000
    5,434
    1,736
    9,110
    Yoyodyne Propulsion Systems
    Doug
    I'd add the Sherbourn 5/1500A to the neutral list. Mine was powering my Diva 6.1/C3/2.1 setup before I purchased different speakers and it sounded divine. They were a good match.
  4. chung_sotheby
    chung_sotheby Supporting Actor
    Apr 8, 2002
    857
    Here are also a couple to add to your list:
    Odyssey Stratos: Warm
    Anthem: Neutral
    Norh Le Amp/ IRD MB100: Neutral/Bright
    Monarchy Audio: Neutral
    Acurus: Neutral/Bright
    PS Audio: Neutral/Warm
