Transfer Songs From One Player To Another? (merged)
Discussion in 'Computers' started by AbelM, Feb 3, 2005.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    How can we do this? Is this posible? My circumstance is that everything is on iTunes (as I was hoping to get an iPOD soon, however, I switched over to Nike or iRIVER) and would like to get all 1400 songs over to either Winamp or Windows Media...any possible way or do I have to pull out the CD's again and redo/burn all songs?
    Abel
  2. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Anyone at all [​IMG]
  3. Patrick_S
    Patrick_S Producer
    Apr 1, 2000
    3,278
    102
    4,110
    Well give us some specifics.
    What file format did you use when you ripped your CDs using iTunes?
  4. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    I just used the normal one that iTunes uses...
  5. EricWilliam
    EricWilliam Agent
    Aug 31, 2004
    37
    if they are MP3's, then you shouldn't have any problem..now tracks purchased from iTunes are a whole other matter...
  6. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    No, everything is CD from my own collection. However, when I burned them to iTunes, I never changed setting to MP3...is there a way to do this?
  7. Scott Merryfield
    Dec 16, 1998
    12,308
    1,066
    9,110
    If you used the iTunes default settings, you probably ripped everything in Apple's AAC format, which will not be compatible with most other players. There are applications available to convert files from one format to another, so you could convert the AAC files to the more common MP3 format. However, the audio quality of the resulting MP3 file will not be as good compared to one ripped directly from the source CD since you will be re-compressing an already compressed audio file.
    Personally, I would re-rip the songs from the original CDs for the better audio quality.
  8. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Gotcha...thx for the info. I will re-rip everything over again...and if I use MP3, I then can transfer over to WM and make a MP3 CD? [​IMG]
  9. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Ok...so I re-ripped about 4 of my CD's over again (because that's what you all suggested to do). Did this, ripped everything in mp3 format on WM and then made an audio cd, not all songs would fit (I was told they would, nope), so I wasted another blank CD, and made a data CD...everything got burned on it, and then my CD player won't play it.
    So....what's wrong here? I just want to make a flippin' mp3 CD...arh, didn't think it would be so hard! [​IMG]
  10. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Just rip your CDs in WAV so you don't have to fool with ripping again. Delete the WAVs when you sucessfully make the CD.
    1) Use EAC or Razorlame to convert the WAVs to MP3, with a bitrate of around 192kbps.
    2) Open Nero, import the mp3s into it, and burn the disc.
    Nero will tell you if all the files will fit before you start burning. If there's still not enough room, do another conversion of the WAVs you ripped but go lower in bitrate.
  11. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Is your CD player even capable of playing MP3 files on a CD? If not, then you're wasting your time burning CDs with MP3s on them. If so, then do what Scott suggests.
  12. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    if you ripped all your songs to mp3, then copied them to a cd -- and they still won't play -- then something is probably wrong with your player. make sure it's capable of playing mp3's. a typical mp3 cd will hold about...i dunno...a hundred or so songs.
    if you do wav files, then *any* cd player will play the songs, but you'll only fit about 15 songs on the cd. also, if you're creating wav files, be sure to use the *original* cd to copy the songs. don't use any of your compressed aac/mp3 files as the source.
  13. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    You can also rip your CD's to MP3 files and then use those MP3 files to create a normal Audio CD - most worthwhile CD-burning programs can convert MP3 files on the fly to CD audio tracks for burning. That will create a normal Audio CD comprising the MP3 tracks you copied to the disc.
    However, if you want to create "standard" MP3 files you should do a little searching here on the forum. There are certain software tools that are recommended to get the best possible rip quality; my personal recommendation is a combo of Exact Audio Copy and the Lame MP3 encoder to create high quality VBR (variable bit rate) MP3 files suitable for archiving (at least in my opinion; some people refuse to archive at anything less than lossless compression, monkeys audio etc other variants of lossless compression.)
  14. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  15. Kimmo Jaskari
    Feb 27, 2000
    1,528
    True enough. Using EAC/Lame and ripping to high-quality VBR you do lose quality but no mere mortal can hear that. VBR can give quality that rivals 320kbit CBR but keeps the file sizes lower.
