Kevin Coleman
- Jul 3, 1999
I sent an E-mail to Bill Hunt about it with links to Bjoern's website. I don't expect him to say much on it but who knows.
Kevin C.
Kevin C.
But Gary, some of those deleted scenes with less ringing also contained *more detail* than the theatrical cut on the disc.
I'm not arguing on the side of the 'source elements are at fault camp.' I haven't watched TPM DVD, and I don't really care to. Obviously something went wrong which caused some nasty halo artifacts on the DVD - I was just explaining that low bit rates will have fewer noticeable halos than high bit rates, due to the low-pass filtering involved. However, since the deleted scenes have more detail and no halos, obviously something else is amiss.
For %90 of the buying public with 27" tvs it may suffice...
The same could be said about the VHS release a year-and-a-half ago.
This DVD should have set a higher standard and not been processed to look sharper on "everyman's" TV set just because that's what he's used to seeing. ... If that's what happened.
The fact that the realtively unprocessed supplements look better points to the "the more buttons I press on my console the better the image quality will be" mentality of studio mastering. With audio mastering, the best sound happens when the sound engineers just let the signal through without manipulating it. The same philosphy holds for video.
Brilliant minds think alike
It seems to me that it's analogous to a record producer so in love with the equipment in the recording studio (an apt description of Lucas) that he decides to process and multitrack and equalize the HELL out of a recording instead of leaving the source in its "natural" state. The result is a decided UNnatural product with false detail at the expense of real detail.
Let's quality that. Your analogy talks about equalizing "the HELL out" of it. I would agree that this can be the case, although it's more likely they'll compress the thing to death to make it louder and reduce any dynammic range.
But realistically, in audio recording, EQ is meant to correct deficiencies in the original recording. The result "should" be what the producer wants. Unnatural is in the ear of the beholder, especially these days. But any audio engineer or producer will tell you that absolutely NO ONE does any recording without EQ. Without it, you end up with a lifeless recording. Even live concerts are processed with EQ before burning to disc.
Audio and visual are two different things. Carrying your analogy to film, I agree that TPM was overly processed, resulting in the effects that we are all (mostly) complaining about. Just as with an audio recording, the processing should be transparent to the end user. The CD listener shouldn't be able to hear too much EQ on a specific instrument track, just as we shouldn't see the visual edge enhancement artifacts on the TPM disc. Just as with audio, a motion picture must be processed before going to DVD. A film that looks great projected on a big screen will not look the same on most television monitors.
But I absolutely agree that someone went way too far with this. After the pains Lucas went through to eliminate the matte effects from the first three films when he released the special editions, I'm really surprised he let this one out of the door so "dirty".
We definitely agree!
-dave
[Edited last by DaViD Boulet on October 19, 2001 at 11:02 AM]
So, the question is, are the Fox reps reading this, and if so, what are they going to do about it????
Let's not get on Fox's case. Lucasfilm had a lot more to do with this dvd than FOX. I mean, When the filmmakers come in and say this is how it should look, what are they to do?
If anyone should be brought to task here I would suggest it be the folks over at THX and Lucasfilm.
