Towers with side firing sub. Why is 6" of clearance needed for these drivers?
Discussion in 'Archived Threads 2001-2004' started by ken thompson, Jan 18, 2002.
  1. ken thompson
    ken thompson Second Unit
    Jun 5, 2000
    251
    When down firing subs have little more than 1"
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Ken,
    I beleive it has more to do with the sub firing directly
    into a corner or ajacent wall. Down Firing subs are firing
    against a floor plane where as the side firing subs could
    be firing into a corner or directly into a wall.
    Positioning of Sub Equipped Towers can be rather critical
    because improper positioning can boost certain frequencies
    that could make the sub sound overly "boomy"
    Plus you don't want the subs firing into objects like a large
    RPTV where it could induce screen shake.
    I run my sub equipped towers with the subs facing away from
    each other and they also have rear firing ports which I keep
    at least a foot or more away from the wall.
