"Touch Up" paint?
Discussion in 'Archived Threads 2001-2004' started by Rob Rodier, Aug 2, 2002.
  1. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    Hi am looking for black touch up paint. I have tried this sort of thing in the past and have seen limited success (to say the least) Has anyone ever used anything that actually worked well? It is for an amplifier that has a minor/moderate scar. Thanks
    -rob
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    If it is an aluminum front panel, there is not much you can do, since it is often an anodized finish.
    There's always good old "Sharpie" pens if it is black (or red [​IMG] ).
  3. Rob Rodier
    Jul 11, 2002
    538
    That explains it. Thanks. I will try the Sharpie again.
    -rob
  4. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    The sharpie should make it is less noticeable. I wouldn't mess with paint. It would probably would cause it to look worse.
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    when i used to do installations, i always kept a sharpie in my toolbox. worked great for covering up small scratches in the equipment. also worked very well for any black wooden/laminate surface.
